This is not a simple to describe. Please be patient. This an example of my issue:
In Sketch Mode. Start a line on a projected end point. My new starting point DOES NOT get constrained to the existing projected geometry. I don't get the GREEN point (at ends or mid of an existing line/edge/point). So I have to go back and manually constrain all my new line/point...sketch entities. I must have changed a setting by mistake 🙂
Can you please help.
Thank you.
Solved by Curtis_Waguespack. Go to Solution.
Hi samuel777,
I suspect you have accidentally disabled the Constraint Inference and/or Constraint Persistence. Here are some links that describe how to turn those back on:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-2833D927-6E48-4973-A330-DDD22E3DEE39
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-6F4B61B3-EF63-4786-BA88-947FDBC24212
http://www.cadsetterout.com/inventor-tutorials/temporarily-turn-off-persistant-constraints/
I hope this helps.
Curtis
