Inventor General
Valued Contributor
jyothissurendran
Message 1 of 20 (572 Views)
Accepted Solution
Plot Date Expression ?
572 Views, 19 Replies
10-22-2012 02:06 AM
i have created Template as per my compnay standards and would like save its as my company standard template (*.idw) file. Everything is done but i need add PLOT DATE on the template file. In autocad its possible by adding fields in text.So i followed the same procedure to add PLOT DATE in inventer template. But i dont find any option for adding PLOT DATE. There is any option available to add field expression or something to get the output plot date ????
Jyothis Surendran
Inventor Professional Suite 2010
Windows 7
Valued Mentor
BLHDrafting
Message 2 of 20 (532 Views)
Re: Plot Date Expression ?
10-22-2012 03:13 PM in reply to: jyothissurendran
Not sure there is an Inventor property for this. Swift Printes (http://cadtoolbox.com/swift-prints/) can do this (and is a very nice printer config tool).
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
Valued Contributor
jyothissurendran
Message 3 of 20 (521 Views)
10-22-2012 09:56 PM in reply to: BLHDrafting
But i was actually searching for something like in autocad, field expressions.
If somebody have any idea please do advise...
Jyothis Surendran
Windows 7
*Expert Elite*
karthur1
Message 4 of 20 (508 Views)
10-23-2012 05:57 AM in reply to: jyothissurendran
Jyothis,
You will not find an expression for this (wish there was though). What we have been using for several years is a "Last Saved on...." stamp. It looks like this on the idw.
If that would work for you, post back and I will explain how to set this up.
Distinguished Contributor
Message 5 of 20 (495 Views)
10-23-2012 09:12 AM in reply to: karthur1
An option that does give you the exact plot time, plus more.
http://www.c3mcad.com/ProductPages/Drawing/ProductPlotStampPlus.aspx
*Expert Elite*
karthur1
Message 6 of 20 (489 Views)
10-23-2012 09:26 AM in reply to: nmunro
C-Cubed has done a great job at filling this void that AD left open. I just really wish that AD would include this with Inventor. (Yes, I have requested this on the AD contact page)
The OP was probably thinking that he could add this easily to the idw like in Acad.
Valued Mentor
BLHDrafting
Message 7 of 20 (471 Views)
10-23-2012 07:03 PM in reply to: karthur1
The only real problem I have with any of the add-in type options is when used in a Vault environment. generally plotting the IDW requires a change to a custom iProperty which then makes the IDW file dirtied. This is why I have stopped using this part of the Swift Prints add-in.
I agree that Autodesk just need to bite the bullet and make this a useable function out of the box.
Brendan Henderson
Web www.blh.com.au
Valued Mentor
BLHDrafting
Message 8 of 20 (469 Views)
10-23-2012 07:10 PM in reply to: nmunro
I haven't seen this one before. The website boldly says "All Plot Stamp Plus actions are completed without dirtying the Autodesk Inventor document" and is this is the case then I might just buy it!
Brendan Henderson
Web www.blh.com.au
Valued Contributor
jyothissurendran
Message 9 of 20 (450 Views)
10-24-2012 02:23 AM in reply to: karthur1
Thanks for the reply. But i dont find any option like "last saved on", i am using INV 2010.
Jyothis Surendran
Windows 7
*Expert Elite*
karthur1
Message 10 of 20 (440 Views)
10-24-2012 05:25 AM in reply to: jyothissurendran
Jyothis,
I have a macro that adds a custom property named "SysDate" and "SysTime".  The code is attached.  Here is how to get this to work:
1. Open your idw template.  Go to Tools>VBA Editor.
2. Under the Autodesk Inventor Node is a "This Document" module, right click on this and choose "View Code".
3. Now copy/paste the code in the attached txt to this node.
Now when you save the idw, you should have a "SysDate" and "SysTime" variable under the custom iproperties that you can use in your expression.
It should look something like this when you are done.
Kirk
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
