Hi I have been using 3ds max 2011, when I moved an object around my x,y,z arrows disappeared, look at the attachments, what I want to get back is the three xyz arrows when im using the move tool or rotate etc.
look at the picture attachments, the two with the green ball are the ones that dont have the xyz movement arrows i want.
Solved by DarrenP. Go to Solution.
http://area.autodesk.com/forum
hit x on your keyboard
FYI
this is the inventor forum not the 3ds max forum
DarrenP
hitting [x] didn't do anything..
could you be more specific?
