Inventor General
*Beissel, Josh
Message 1 of 3 (243 Views)
Placing Centerline on an arc
243 Views, 2 Replies
11-05-2002 10:33 PM
Is it Possible to place a centerline on a drawing that has an arc or radius?
(example: any dia. bar with a 90deg. bend or any deg. bend.) I want the CL
to follow the bend or arc that is placed not just straight lines horizontal
or vertical. I can get centerlines on my drawing as long as the lines I'm
working with are parallel or holes. I hope this is enough information.
Thanks Josh
Distinguished Contributor
Message 2 of 3 (243 Views)
Re: Placing Centerline on an arc
11-06-2002 12:07 AM in reply to: *Beissel, Josh
If I understand correct. You have to do use a center line bisector pick the two arc lines
*Beissel, Josh
Message 3 of 3 (243 Views)
Re:
11-06-2002 12:24 AM in reply to: *Beissel, Josh
Yes that worked.  I used all of the tools
except that one when I was trying.  thanks
If
arc lines
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
