Inventor General
Member
aaddekrom2279
Message 1 of 7 (139 Views)
Placed Tooling Part Invisible ?
139 Views, 6 Replies
05-13-2009 03:23 AM
When I place a plastic part (or Core/Cavity) in a Mold Design iam. The screen stays empty.....
Editing it via the browser shows the parts are there ?!?
Also the Cube dissapears......
So what is going on ?
All drivers updated, XP64bit, QuadroFX4600, 8GRam
JDMather
Message 2 of 7 (139 Views)
Re: Placed Tooling Part Invisible ?
05-13-2009 06:32 AM in reply to: aaddekrom2279
If you reboot does the ViewCube return?
Does the part in the Mold Design Tutorial work?
Can you zip and attach the assembly here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
aaddekrom2279
Message 3 of 7 (139 Views)
05-13-2009 07:12 AM in reply to: aaddekrom2279
Reboot nor reinstalling Tooling changed something.
Cube is there but when i point at it or at the node from the mobile in the browser, CPU usage goes up for a
while, after that Cube dissapears or freezes.
I can edit the base component of the Mobile, no issues in the part environment there.
Attached the iam and an image.
Member
aaddekrom2279
Message 4 of 7 (139 Views)
05-13-2009 07:34 AM in reply to: aaddekrom2279
Update;
Placing the assembly in an idw works fine.
*Henry Zhao\(Autodesk\)
Message 5 of 7 (139 Views)
05-13-2009 11:09 PM in reply to: aaddekrom2279
I can see the invisibility issue after opening your
attached assembly.
You can try to press "Home" Key or click "Zoom All"
command in the Ribbon tab. It will zoom the part into the graphic
window.
I am not sure what's the reason about this issue.
Could you please post your detail workflow about the creation? So that we can
reproduce and investigate it.
Henry
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
Reboot
nor reinstalling Tooling changed something. Cube is there but when i point at
while, after that Cube dissapears or freezes. I can edit the base component of
the Mobile, no issues in the part environment there. Attached the iam and an
image.
Member
aaddekrom2279
Message 6 of 7 (139 Views)
05-17-2009 09:56 PM in reply to: aaddekrom2279
I tried "zoom all", "find in window" etc....
Just followed (exactly) the instructions from the "general mold workflow" tutorial that comes with tooling.
When i place other parts than the mobile it makes no difference, nothing will show up.
Changing Color or Display options make no difference.
Roll Back Graphics driver make no difference.
JDMather
Message 7 of 7 (139 Views)
05-18-2009 04:52 AM in reply to: aaddekrom2279
Zip and attach the assembly here.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
