Inventor Forum
Place iLogic Component Doesn't Work!!!!
1 REPLY 1
ludesroc
329 Views, 1 Reply
I created a simple Part with some parameters to drive dimensions. Saved the part. I created an Assembly. Saved the assembly. Clicked Place iLogic Component. The Place iLogic Component window appeared Selected the Part. I can see the preview window (Part-01) & the parameter window... Used default values. Hit OK NO PART INSERTED!!!! Using Inventor Pro 2014 64-Bit
Ludesroc
1 REPLY 1
4donwan4
in reply to: ludesroc
The support for ILogic issues remains here in the forums as there are many users who use this feature and can offer advice. Because it involves custom code it is something of a unique nature thar we cannot troubleshoot. The only option I could give you would be to consult your reseller if need be as they may have someone who can assist you with this.
Don
