Inventor General
Active Contributor
conbuc
Message 1 of 5 (373 Views)
Place a hole referenced from a plane instead of an edge.
373 Views, 4 Replies
10-19-2012 11:26 AM
I would like to use the hole command to place a hole in a part. When I place the hole it won't allow me to use one of the origin planes to locate the hole from. Can I only locate holes off edges?
Curtis_Waguespack
Message 2 of 5 (370 Views)
Re: Place a hole referenced from a plane instead of an edge.
10-19-2012 11:34 AM in reply to: conbuc
Hi conbuc,
If you create a sketch on the plane and insert a sketch point, you can then create the hole from the sketch point using the hole tool.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
mrattray
Message 3 of 5 (359 Views)
10-19-2012 12:12 PM in reply to: Curtis_Waguespack
This is the only workflow I use for holes. I never liked using the hole command's dialog for defining the hole position in Inventor or SolidWorks.
Mike (not Matt) Rattray
*Pro
sbixler
Message 4 of 5 (323 Views)
10-20-2012 11:07 AM in reply to: mrattray
I agree, with a couple of exceptions-- creating a sketch for a hole concentric to another circular feature is way more work and no improvement over using the Concentric placement option.  And once in a while, the Point option also saves a lot of work.
Active Contributor
conbuc
Message 5 of 5 (273 Views)
10-22-2012 07:19 AM in reply to: sbixler
Thank you all for the responses. I will use sketches to place or locate my holes.
It does suprise me however that Inventor would not allow the hole to be referenced off of edges AND/OR planes. Inventor already knows where the planes are and in many cases I want the holes to stay put based on the center of the part, not off one edge.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
