Inventor Forum
Place a hole referenced from a plane instead of an edge.
4 REPLIES 4
1412 Views, 4 Replies
I would like to use the hole command to place a hole in a part. When I place the hole it won't allow me to use one of the origin planes to locate the hole from. Can I only locate holes off edges?
4 REPLIES 4
Curtis_Waguespack
Hi conbuc,
If you create a sketch on the plane and insert a sketch point, you can then create the hole from the sketch point using the hole tool.
I hope this helps.
Curtis
This is the only workflow I use for holes. I never liked using the hole command's dialog for defining the hole position in Inventor or SolidWorks.
Mike (not Matt) Rattray
SBix26
in reply to: mrattray
I agree, with a couple of exceptions-- creating a sketch for a hole concentric to another circular feature is way more work and no improvement over using the Concentric placement option.  And once in a while, the Point option also saves a lot of work.
in reply to: SBix26
Thank you all for the responses. I will use sketches to place or locate my holes.
It does suprise me however that Inventor would not allow the hole to be referenced off of edges AND/OR planes. Inventor already knows where the planes are and in many cases I want the holes to stay put based on the center of the part, not off one edge.
