Inventor General
HPsteam
Message 1 of 7 (548 Views)
Accepted Solution
Pipe intersection
548 Views, 6 Replies
10-03-2012 09:48 AM
Hi guys,
hopefully someone could help me out with this problem.
I am in process of preparing an iPart for products we are fabricating that has pipes, fittings, flanges etc... My main problem is creating piping interection. Something that looks like a nozzle on a shell & tube heat exchangers. Basically fabricated reducing Tee. I have tried all of the combine methods, multi-body part, assembly and none of the solutions gives me what i exactly want. I would probably be able to make it with one round boudy cutting out of the larger shell and then one more extruded sketch (pipe for the nozzle/neck) but i am affraid that will create problems when sizes of the pipes vary + it will still be protruding into the shell, not terminating at the (inside / outside) surface of the shell.
I will have a larger shell varying between 5" and 48", while smaller can go anywhere between 1" and 36". Can someone help me how to do this.
I am currently running 2010 ver, but soon we are supposed to upgrade to 2013. So please specify for which version when replying.
i did not attach any part since it is straight forward pipe branch at 90° angle
Any kind of help will be appreciated,
thanks,
(low esteem) HPsteam
Valued Mentor
japike
Message 2 of 7 (541 Views)
Re: Pipe intersection
10-03-2012 10:24 AM in reply to: HPsteam
Are you looking for something like this?
Peace,
Jeff
Inventor 2013
HPsteam
Message 3 of 7 (536 Views)
10-03-2012 10:26 AM in reply to: japike
Yes... that would be pretty much what i am looking for
Valued Mentor
japike
Message 4 of 7 (529 Views)
10-03-2012 10:32 AM in reply to: HPsteam
I'm using 2013, so the part won't help you, but you should be able to build your own following the the features in the browser.
Peace,
Jeff
Inventor 2013
HPsteam
Message 5 of 7 (526 Views)
10-03-2012 10:36 AM in reply to: japike
japike,
thank you for the answers..
The only way i could do it is to have two cylinders as a start, and then create new sketch of smaller cylinders, and cut-out thru both of them. That will give me geometry i need, but it seems like there should be an easier way of doing this.
would you be able to explain hwo to get there, if there is an easier way?
Valued Mentor
japike
Message 6 of 7 (514 Views)
10-03-2012 10:48 AM in reply to: HPsteam
Did you try to follow the feature tree in the picture I posted?
If so, where are you getting stuck?
Peace,
Jeff
Inventor 2013
HPsteam
Message 7 of 7 (502 Views)
10-03-2012 11:02 AM in reply to: japike
it was not clear which steps you have taken...but since you used thicken the only thing would be to use surfaces... that was so easy... i knew that there is easier way, but was not thinking of thickening the surfaces...
thanks a lot  !!!!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
