Inventor Forum
Pipe and Tube in Inventor 2013 Plant Design are missing
11 REPLIES 11
Message 1 of 12
John7911
1845 Views, 11 Replies
I work with Autodesk Plant Design Suite Ultimate 2013, and I can't find Tube and Pipe?
Is it installed in this version?
Thank you 😉
11 REPLIES 11
Message 2 of 12
cbenner
in reply to: John7911
First off, did you get the "Ultimate" versionof the suite so that you actually have Inventor?  I assume so, but I thought I'd ask.
If yes, look in your Inventor under Tool\ Add Ins (on the ribbon menu).  This will bring up the add ins for your Inventor.  Look to see if Routed Systems: Tube & Pipe is loaded.  If not, check the two boxes at the bottom (see pic) and restart Inventor.
If it does not show up, you may want to contact your reseller.  Since Plant Design Suite comes with the Plant Design 3D software, the routed systems may or may not be loaded in your inventor
Message 3 of 12
mflayler2
Plant Design Suite does not come with Inventor Professional, only Inventor Series.  You will have to have another license of Inventor with Professional to use Tube & Pipe, FEA, Simulation, or Tooling
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 4 of 12
rdyson
in reply to: mflayler2
Mark,
2013 vanilla comes with routed systems.
Seems odd that it wouldn't be included with Plant Design
PDSU 2016
Message 5 of 12
mflayler2
On the PrDS side, the Standard only comes with Inventor Series, Premium with Routed Systems, and Ultimate with Professional.
Message 6 of 12
cbenner
Mark,
Thanks for the clarification.  I wasn't sure what came with Plant Design Suite, we use the Product Design Suite, that one has IV Pro out of the box (with the Ultimate at least).  I guess Plant Design Suite assumes you are going to use 3D Plant Design for your piping?
Message 7 of 12
mflayler2
in reply to: cbenner
The assumed workflow with Inventor in Plant Design Suite is so a user can make complex equipment and then use the BIM Exhange environment to create an ADSK with Piping connections that will automatically be picked up after translation of the ADSK into Plant 3D.  So yeah, the piping is assumed to be completed in Plant while the space claim and connections can be defined by a more robust modeling program.
Message 8 of 12
cbenner
Sounds cool,  if our systems get any bigger we may have to consider that direction.  Currently we stick with Tube & Pipe because all of our systems are skid mounted.  So Product Suite is perfect... or would be if they added Acad P&ID.
Message 9 of 12
mflayler2
Although its not AutoCAD PID, have you tried Electrical's PID system for Hydraulic, Pnuematic, and Instrumentation symbols and line work?  I've used PID so I'm a little spoiled, but Electrical's can get you by in a budget pinch.
Message 10 of 12
cbenner
We just started using Electrical this fall, so I haven't had the chance to try a P&ID using that system yet... I am curious though so I probably will play around with it.
Message 11 of 12
mflayler2
Quick tip to find the symbol libraries...they are under the Schematic Tab, in the first Expanded Panel.  You use AEWIRE for the lines and you can create wire types as the line schedules.  I'll attach a few docs for reference.
Message 12 of 12
cbenner
