I am new to Autodesk Inventor and unsure if the following is possible. I would like to design a pipe in the shape of a kudu horn or shofar (see attached). The cross section of this pipe is approximately elliptical/egg shaped and its inner diameter decreases along the longitudinal axis. The pipe is then wrapped around another imaginary cone.
Any help is greatly appreciated.
Kind Regards,
Jordan
Hi Jordan
You can use sweep feature; 1- use 3D sketch to make the sweep path
2-use sweep taper option
See attachment
Kudu horns are incredibly complex. I am currently doing a 3D scan of the inside portion. I made a mold of two incarnations, and I got it close.
