Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
Did you mean:Ā
Physical properties notation
6 REPLIES 6
Bpom
1125 Views, 6 Replies
I have some issues with the notation for physical properties in the Inventor 2013 material editor.
Instead of displaying the obvious first choice metric SI notation kg/m^3 or something similar it display a self made? and awkward N*s^2/mm^4. I don't want this notation. How can I change to something more user friendly? It can be a bit hard to distinguish if a material have 0.00000000001 N*s^2/mm^4 or 0.0000000001 N*s^2/mm^4.
The document properties "units" folder have mm, seconds, degree and kilogram as default.
Running Inventor suite SP1.1 on 64bit vista.
6 REPLIES 6
ChrisMitchell01
in reply to: Bpom
Down at the bottom left of the material or appearance browser/editor there is an option to set the units of display for physical properties. The units of display for materials/appearances are now unrelated to your document settings.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Bpom
in reply to: ChrisMitchell01
Thanks, that did do the trick  šŸ™‚
tommy-z
in reply to: Bpom
Anyone who knows how to get the previous Materials Editor back?
Tried, unsuccessfully, to add a new material.
The functionality of the new and 'improved' materials handling is totally beyond me, I simply do not get it šŸ˜ž
tommy-z
in reply to: tommy-z
And, the button (or whatever it's called) which Chris Mitchell speaks about, allowing change of the units of the Materials Editor, does not appear to be part of my installation.
LT.Rusty
It's in a REALLY counterintuitive location.  It's on the material browser window, not the material editor.  Click the pulldown that looks like a little gear, then you'll find what you're looking for.
Rusty
tommy-z
in reply to: LT.Rusty
Thanks, I found it, in the - like you said - counterintuitive location.
The whole new materials thing is extremely counterintuitive, I find.
Another 'funny' observation: When entering the density of an insulation material, which is: 80 kg/mĀ³ the wonderful application 'corrects' that to: 8,000E+01 kg/mĀ³!?
Talk about counterintuitive šŸ™‚
