Inventor General
Active Member
bogdan.noreq
Message 1 of 7 (337 Views)
Pattern visibility
337 Views, 6 Replies
06-28-2012 11:26 PM
Hi!
Can anybody explain to me why if in .iam view representation I make "component patterns" invisible, thay still on .idw drawing are visible, and worse part is that I can not turn off visibility manually in browser. Please see attach.
Thank you for your time :smileyhappy:
Autodesk Inventor Professional 2013
Windows 7 64-bit
Valued Mentor
Message 2 of 7 (309 Views)
Re: Pattern visibility
06-29-2012 05:16 AM in reply to: bogdan.noreq
If I remember correctly - it is not enough just to turn the visibility of the pattern off. You have to expand the Pattern node and turn the visibility of the members off as well.
Igor.
Web: www.meqc.com.au
Valued Mentor
Message 3 of 7 (303 Views)
06-29-2012 05:27 AM in reply to: bogdan.noreq
Better yet - make sure the drawing view is associative to the assembly. Here is a snap shot of what to look for.
Igor.
Distinguished Contributor
andrewiv
Message 4 of 7 (284 Views)
06-29-2012 05:53 AM in reply to: bogdan.noreq
I've had this same issue with IV 2012 SP2.  They release a hotfix to correct the issue for 2012, but not sure about 2013.
Inventor Professional 2014 SP1
Active Member
bogdan.noreq
Message 5 of 7 (282 Views)
06-29-2012 05:55 AM in reply to: IgorMir
Hi!
Thanks for answer. Yes - it is checked. I think it is by default always checked.
I do not want to expand pattern - it make assemblys list full of not useful information :smileysad:
Спасибо за ответ! :smileyhappy:
Windows 7 64-bit
Valued Mentor
Message 6 of 7 (256 Views)
06-29-2012 06:50 PM in reply to: bogdan.noreq
Then it is probably a bug in the latest release of IV. In IV2010 it works - as expected.
Best Regards,
Igor.
P.S. Привет, Богдан! Рад помочь, если могу. Где Вы живёте? Для переписки на русском - можно использовать мой адрес со страницы. До связи!
Product Support
innovatenate
Message 7 of 7 (207 Views)
07-17-2012 05:06 PM in reply to: bogdan.noreq
I am not able to reproduce this using simple assembly that I have created to test this. I've uploaded my test files to this post. I'm think you may be in a Master View Representation or perhaps the View Representation is Locked
Please see the attachments for clarification.
Nathan Chandler
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
