Inventor Forum
Pattern subassembly by parameter
2 REPLIES 2
RobinDhondt
257 Views, 2 Replies
Hi all,
I've got the following problem:
In my head assembly I have a subassembly that has derived parts from my skeleton. My skeleton (part ending with skt in the picture) is in the subassembly.
In this subassembly I made a view representation: NoSKT
When this is activated the skeleton is hided (see picture).
If I now make a pattern of this subassembly in my headassembly with for example a parameter from my embedded excel or a parameter in inventor "quantity = 2" inventor will add 1 element with the same view representation. Still no problem.
The problem is now when I change the parameter. If I change the quantity to for example 3, the view representation of the third element is gone and the skeleton will become visible.
I have many parts like this in my headassembly and quite a lot of patterns. Which means a lot of skeletons become visible. Is there a way to stop this from happening?
Thank you in advance!
2 REPLIES 2
CCarreiras
in reply to: RobinDhondt
Hi!!
I think, perhaps, are those things that happen in the browser that no one can explain ... because it works for element 2, should work the same for the element 3.
Where is the view representation in element 3??!!
Someone?
Regards.
CCarreiras
RobinDhondt
in reply to: CCarreiras
Seriously... no one?
