Solved by Curtis_Waguespack. Go to Solution.
Hi JoeyG23832,
You should be able to:
It sounds like you might have tried this already, if so more detail about what is not working might help.
Also, it might be helpful for you to create a very basic data set to upload or share screen captures with the forum to help troubleshoot, since you can not share your actual work.
I hope this helps.
Curtis
