Inventor Forum
Pattern a solidbody, while drecreasing it's size
5 REPLIES 5
staale
351 Views, 5 Replies
I have a question, I have not been able to solve yet. I'm looking to pattern a solid inside a multibodypart, while decreasing its size to fit inside.
Hope someone could help me with this, cause as usual tight deadline Smiley Tongue
See attached picture.
5 REPLIES 5
VdVeek
in reply to: staale
Have a look at iCopy. The help function gives you an example of a ladder which looks the same like your design.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
staale
in reply to: VdVeek
Hi and thanks for reply.
ICopy aren't available in a Multibody, or am I missing something?
Staale
VdVeek
in reply to: staale
ICopy isn't available in multibody. But why are you creating this in multibody? In the real world this will be multiple parts, so why not create it that way?
Rob.
staale
in reply to: VdVeek
The reason is that I wanted to run this in Dynamic Simulation, but you are correct, in the real world this would be multiple parts, but I do Make Componets of my multibody parts.
But it looks like it will be better to just make the shell a multibody and then use framemaker to add the stiffening girders inside the shell.
The multibody-parts can get to complicated when you add to many parts to it.
nannerdw
in reply to: staale
You can shinkwrap the assembly file if you need a simplified version of it, too.
