Inventor General
JDMather
Message 11 of 13 (497 Views)
Re: Parts not visible in .idw
12-17-2010 12:33 PM in reply to: pjpickard
The quality of this file is not particularly good -
- it is only a single side surface body (no part thickness)
- it is missing many faces in the surface that is there.
If you don't need to edit the part and don't need mass properties (like weight) there is really no overwhelming need for a solid. I normally like to convert imported geometry into a solid - but from what I can see of your picture this would be an off-the-shelf purchase and no real need for solid.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
pjpickard
Message 12 of 13 (473 Views)
12-19-2010 12:53 PM in reply to: JDMather
JD,
yes its an off the shelf I only need it for sizing, it is getting built into a unit.
I would like to know how to convert imports to a solid though. I did not have any luck following what I on this forum and in the help. I'm missing some key thing I fear.
Thanks for your help!
Paul
JDMather
Message 13 of 13 (465 Views)
12-20-2010 04:38 AM in reply to: pjpickard
That particular file is garbage and would take several hours to get a solid. (Mosty thicken - might be faster to use as reference and remodel.  No easy button solution for that file.
More information here http://au.autodesk.com/?nd=class&session_id=3056
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
