Inventor Forum
Parts lists, IPNs & IDW
4 REPLIES 4
164 Views, 4 Replies
Perhaps I missed a posting or was sleeping or
something.  I have been creating IPNs with multiple exploded views based on
different design views of the assembly.  When I place the IPN views in an
IDW, each view seems to balloon from its own parts list.  Is there a way to
sync the parts lists so the item numbers match or must they be edited manually
or is there a way to balloon each view from a single parts list
occurrence?  This question applies to all views on one sheet and different
views on multiple sheets.
TIA
Hal Gwin
Mechanical
Designer
Xenogen
4 REPLIES 4
I have been going through the same thing. To the best of my knowledge that functionality
isn't there. I will be a happy man if someone proves me wrong, but at this point I think
it is just a wishlist item.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Hal Gwin" wrote in message
Is there a way to sync the parts lists so the item numbers match or must they be edited
manually or is there a way to balloon each view from a single parts list occurrence? This
question applies to all views on one sheet and different views on multiple sheets.
I could never understand the logic of linking part lists to views. It
seems totally absurd to me. When I create an assembly I want one and
only one master part list for that assembly. And I want all the balloons
to reference that one list. There should be an option to pick one part
list that the ballons will reference.
In order to expand my viewpoint, I would be interested in hearing
scenarios of why anyone would every want to reference more than one part
list, for one particular assembly.
Aaron R. Friedman
ARF Designs
> Kent
Since no one has responded with scenarios of balloons referencing more
than one part list for a particular assembly, can I assume that no one
does, and that the Inventor team is way off the mark in assuming that
is how people work?
Aaron
> Aaron R. Friedman
> ARF Designs
No way to add the detail sheet number to a balloon either. If you add
another parts list the balloon numbers aren't coordinated either. The
drawing module needs work. ... Guess I'm repeating myself all over again?
~Larry
"Aaron R. Friedman" wrote in message
news:3E40B154.9050103@xprt.net...
> is how people work?
> Aaron
> > Aaron R. Friedman
> > ARF Designs
