Inventor Forum
Parts list for multiple configurations
6 REPLIES 6
630 Views, 6 Replies
I design rubber molds.  So, you have a cap, base, inserts, end plates... yadda yadda.  Sometimes we use different configurations of a mold to make slightly different parts.  For example, say by default, the "-1" configuration will be basically just the cap and base, to create a 6" part.  Then, we might have a "-2" configuration with a 1" spacer insert to create a 5" part.  What I want, is a parts list to automatically pull in the quantities for the different configurations in separate columns of the parts list.  I'm wondering if there is a way to do this using different Level of Details.  One solution I've contemplated is creating the parts list from the "default" assy, then creating a "parts list" of the alternate assembly, but stripping off all but the quantity column... but that doesn't seem horribly elegant, and I'm not sure I can resolve all parts list rows without pegging in some dummy "custom parts".... dunno.
Thoughts?
6 REPLIES 6
Cadmanto
Are you looking for something like this?
Found here if you edit the parts list.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: Cadmanto
YES, that's in the right direction.  How do you get that "Member Selection" button to light up... is this done using different LODs?
Cadmanto
After you have created your iassemblies, in your drawing place a parts list based off of one of your views.
Then RC on the PL and select this.
This gets you to the screen shots I provided in my last posting.
Once you get to the member list just check the ones you want represented.
Hope this makes sense.
This has nothing to do with LOD's.
Best Regards,
Scott McFadden
AH, iAssemblies... gotcha.  Think I can figure it out from here.  Thanks!
JimSteinmeyer
Yoda-Scott the parts list master !Heart
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
Cadmanto
in reply to: JimSteinmeyer
My Buddy, many thanks to....says Yoda!!!!  Smiley LOL
Best Regards,
Scott McFadden
