Inventor General
Valued Contributor
Message 1 of 8 (251 Views)
Partlist on dwg-drawing from idw
251 Views, 7 Replies
03-24-2010 05:32 AM
When I save an idw as autocad dwg, the partlist is only a block made up by many pieces of text (not a table). It is not possible to copy text from multiple cells in rows/column in the partlist and paste it into excel...
Anyone got a solution for this?
Best regards
TG
Autodesk Inventor/Vault Professional 2013
Distinguished Contributor
Message 2 of 8 (251 Views)
Re: Partlist on dwg-drawing from idw
03-24-2010 05:44 AM in reply to: tegstette
After selecting the data you wish to copy from the parts list use "Ctrl-C" to copy. You can then paste it into excel.
2010 Suite-SP4 64bit
Valued Contributor
Message 3 of 8 (251 Views)
03-24-2010 05:56 AM in reply to: tegstette
Yes, this works when I edit the partlist in the original 3D idw-drawing.
But then I make an autocad-dwg-drawing (not inventor dwg) from the idw to give to my customer. And when my customers open the dwg-drawing the partlist in this drawing is only a big block made up by many blocks of text... and we find no way to copy/paste data from the partlist...
Best regards
TG
*Dennis Jeffrey
Message 4 of 8 (251 Views)
03-24-2010 09:15 AM in reply to: tegstette
You can export a parts list as an xls file.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Subscribe to the free "The Creative Inventor Magazine now available at:
http://teknigroup.com/CI-Subscribe-Login.asp
Valued Contributor
Message 5 of 8 (251 Views)
03-25-2010 03:49 AM in reply to: tegstette
I know I can export part list from the idw, but can my customer export the partlist from the autocad-dwg (created from idw)? He does not have Inventor, only autocad... (sometimes he needs to get data from some of the partlist)
Best regards
TG
*Dennis Jeffrey
Message 6 of 8 (251 Views)
03-25-2010 04:34 AM in reply to: tegstette
No. You did not explain yourself fully in your post. However, you can
export, then link that into AutoCAD or send it separately.
Valued Contributor
Message 7 of 8 (251 Views)
03-26-2010 03:40 AM in reply to: tegstette
I am sorry for the imprecise question. Not always so easy to explain a problem:-)
But what I really want to know is if there is a way to set up the "save as autocad-dwg" in a way that makes the partlist on the autocad dwg-drawing a table - not only a dumb block made up by many other blocks of text.
I find it strange that this is not the way it is... especially since both idw and dwg is autodesk-formats
Best regards
TG
Message 8 of 8 (251 Views)
03-26-2010 07:01 AM in reply to: tegstette
Simple explanation IV requires Excel to run which is why you can do al sorts of things with it. ACAD and other 2D drawing programs do not have this link or requirement. 2D programs are just electronic versions of dumb hand drawn paper drawings. This is the difference between a parametric modeler and a dumb flat filing system 2D drawing program. And yes i'm using a hammer.
MSK
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
