Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Part forming question
3 REPLIES 3
sps_cad_guy
262 Views, 3 Replies
I am working on a part where the customer is supplying us with some blank
plates 24" square. They want us to put a 4" bent leg on the part.
What I need to know is, in Inventor, how do I go about this?
I have done this in SW, but can not figure out how in Inventor.
Thank you very much for  your help.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2014 SP2
ACAD Mechanical 2014
3 REPLIES 3
JDMather
in reply to: sps_cad_guy
Bend Part (hidden command).
But I would probably model as-bent.
mpatchus
The bend faeture works pretty well for simple bends.
But as JD said, more complex parts work better by modeling.
Or go into the Sheet Metal environment.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. šŸ™‚
sps_cad_guy
in reply to: mpatchus
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2014 SP2
