Inventor General
Distinguished Contributor
SKinzel
Message 1 of 36 (826 Views)
Part Quantities
826 Views, 35 Replies
01-18-2013 09:31 AM
Our individual part drawings reference the quantity of that part used in an assembly.  Is there any way to get the quantity number for a part from an assembly and insert it in the individual part drawing?  Currently I manually put this in but sometimes I forget to do this or I enter an incorrect number.
I haven't been able to find anyway to do this but any ideas on how to do this to keep my opportunites to make a mistake to a minimum?
Stuart Kinzel
Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
8GB memory
Windows 7 64bit
cwhetten
Message 2 of 36 (819 Views)
Re: Part Quantities
01-18-2013 09:55 AM in reply to: SKinzel
You could probably do this with iLogic.  I can look into the code required to do this, if you think an iLogic solution is acceptable.
-cwhetten
cwhetten
Message 3 of 36 (810 Views)
Re: Part Quantities
01-18-2013 10:30 AM in reply to: SKinzel
It wasn't too hard, so I did it anyway.  You will probably want to create a custom iProperty in the part to store the value of the assembly quantity.  For example, if your assembly number is 4100, then you could create a custom iProperty called "4100_QTY" (you'll want to name your custom iProperty with some kind of reference to the assembly into which it is placed, since this part may be in multiple assemblies in different quantities).  Then in your assembly, you would have an iLogic rule that has the following code:
iProperties.Value("ComponentName:1", "Custom", "4100_QTY") = ThisBOM.CalculateQuantity("Model Data", "ComponentName:1")
Of course, change the "ComponentName:1" value to whatever your part is named in your assembly browser.  You'll have to make sure this rule is run if you make any changes to your assembly, so that the quantity value stored in each part is always up-to-date.  You could use event triggers for this, or some other method, or just remember to manually run your rule before you update your drawings.
You will have a similar line of code for each component you wish to treat this way.
-cwhetten
Please click "Accept as Solution" if this response answers your question.
SKinzel
Message 4 of 36 (807 Views)
Re: Part Quantities
01-18-2013 10:36 AM in reply to: SKinzel
Thank you.  I'm just starting to learn about iLogic.  I'll try this out.
As I understand it the rule is in the ASSEMBLY and will need to be triggered.  I am thinking that maybe the rule would be triggered on any SAVE of the assembly.  Then when I open the part drawing it should automatically update, correct?
Stuart Kinzel
8GB memory
Windows 7 64bit
cwhetten
Message 5 of 36 (791 Views)
Re: Part Quantities
01-18-2013 12:51 PM in reply to: SKinzel
Yes, that would work.  You should set it to trigger BEFORE a save event, so that it saves the documents with the updated numbers.
-cwhetten
Valued Mentor
rhasell
Message 6 of 36 (760 Views)
Re: Part Quantities
01-20-2013 03:39 PM in reply to: cwhetten
Hi
I just tested the iLogoc code, pretty cool, It might become painful with a few hundred parts though, perhaps I missed something?
Up until now when I have needed this particular feature, is to just to it manually, using a copy and paste.
Also having the custom field in the Assembly, highlight the entire QTY column, and copy it to the new custom column. It is still a manual process which is succeptable to errors, but pretty quick to do.
Reg
Autodesk PDS Ultimate 2015 Update 1 Build 159
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it fixes your problem.
cwhetten
Message 7 of 36 (730 Views)
Re: Part Quantities
01-21-2013 10:41 AM in reply to: rhasell
You're right, having to add a line for each component is a pain, and you would have to remember to add new lines or remove lines if you add or remove components from your assembly.  Not ideal.
With that in mind, I modified the code to take care of these issues.  Here it is:
oCompDef = ThisDoc.Document.ComponentDefinition
Dim oCompOcc As Inventor.ComponentOccurrence
'get the part number of this assembly and use it to build the name of a custom property, i.e. "4100_QTY"
customPropertyName = CStr(iProperties.Value("Project", "Part Number")) & "_QTY"
'loop through each component in this assembly
For Each oCompOcc In oCompDef.Occurrences
    oCompName = oCompOcc.Name
    'get the part number of the current occurrence
    oCompPartNumber = oCompOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
    customPropertySet = oCompOcc.Definition.Document.PropertySets.Item("Inventor User Defined Properties")
    'test if the custom property already exists
    Try
        prop = customPropertySet.Item(customPropertyName)
    Catch
        'assume error means iProperty doesn't exist, so create the property
        customPropertySet.Add(0, customPropertyName)
    End Try
    'set the value of the custom property in the current occurrence to equal its quantity in the assembly
    iProperties.Value(oCompName, "Custom", customPropertyName) = ThisBOM.CalculateQuantity("Model Data", oCompPartNumber)
Next
iLogicVb.UpdateWhenDone = True
This new code will work no matter how many components are in the assembly, and even works (without modification) when you add or remove components.
I wrote it to build the name of the custom iProperty based on the part number of the assembly that contains the rule.  So, like in the example I mentioned earlier, if your assembly part number is 4100, then this code will take that value and create a custom iProperty called 4100_QTY.  You can modify this to be whatever you wish.  If you aren't sure how to do that, just ask and I can help you modify the code.
This rule is flexible enough that you can copy and paste it into any of your assemblies without modifying the code.
-cwhetten
SKinzel
Message 8 of 36 (726 Views)
Re: Part Quantities
01-21-2013 10:44 AM in reply to: SKinzel
Thanks.  I'm definately going to give this a try.  It might be a couple of weeks before I get time to play with it.
Stuart Kinzel
8GB memory
Windows 7 64bit
Valued Mentor
rhasell
Message 9 of 36 (702 Views)
Re: Part Quantities
01-21-2013 03:13 PM in reply to: cwhetten
Very cool, thanks.
I have run it briefly and will definately store it for later use. Does what you said it would, I will probably add some some code from other snippets to step through the Sub-assemblies as well, if I get it right I will post the update.
With a bit of modification this snippet has lots of other uses as well.
Reg
cwhetten
Message 10 of 36 (695 Views)
Re: Part Quantities
01-21-2013 03:39 PM in reply to: rhasell
I also thought about going through sub-assemblies.  But, you might not always want to do that.  If some of your sub-assemblies have drawings of their own, then you would want its sub-components to have quantities from the sub-assembly, not the higher assembly, right?
Then again, if some of your sub-assemblies are phantom, then you would definitely want the rule to run through them and set the quantities of the sub-components from the highter assembly.
It's kinda tricky.
-cwhetten
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
