Inventor Forum
Part Numbers not in BOM
10 REPLIES 10
Message 1 of 11
sperrin658
663 Views, 10 Replies
I have an assembly made of three parts. There is ilogic in place to rearrange these parts in the assembly. The part numbers change depending on how the puts are arranged and there length. The part numbers come up fine in the assembly ( i have a window popping up to show them). However when i open the BOM the separate parts are listed but not with there part number just with there file name..
Suggestions please!?
10 REPLIES 10
Message 2 of 11
yannick3
in reply to: sperrin658
Hi
maybe your rule don't set the new part number on each part
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Message 3 of 11
sperrin658
in reply to: yannick3
Its hard to explain... Depending what way the parts are laid out in the assembly using the ilogic iv done changes what the part numbers are.. So without all the parts together the part numbers cant work. I need the indivdual parts to have the same part numbers that are created in the assembly in which they are placed.
Message 4 of 11
Hi sperrin658,
Can you post a screen shot of your BOM dialog, so we can see the issue you are seeing?
I suspect the issue might be related to the  Part Number Row Merge Settings:
http://inventortrenches.blogspot.com/2011/08/unwanted-varies-and-merged-part-numbers.html
But it's difficult to know without seeing the BOM dialog.
I hope this helps.
Curtis
Message 5 of 11
2 images one shows the BOM which only shows the file names.. The other shows the assembly and the part numbers being displayed within the assembly.
Message 6 of 11
Hi sperrin658,
It looks like maybe the part number string is being created and reported in the iLogic rule, but not actually written to the part file's iProperty (which is what yannick3 guessed might be happening).
Would it be a good idea to post your iLogic code at this point?
I hope this helps.
Curtis
Message 7 of 11
sperrin658
If Right_On = True And Left_On = False And Center_On = False And Connecting_Plate_On = True
GoExcel.CellValue("SPERRIN COMPONENT NUMBERS - INVENTOR USE.xlsm", "DRIVE IN 0R THROUGH RAIL", "C21") = component_type
GoExcel.CurrentCellValue("C21") = "DRIVE IN / THROUGH RAIL"
GoExcel.CellValue("SPERRIN COMPONENT NUMBERS - INVENTOR USE.xlsm", "DRIVE IN 0R THROUGH RAIL", "D21") = component_type
GoExcel.CurrentCellValue("D21") =  "80MM SPERRIN MK 2 - 2.3MM GUAGE"
GoExcel.CellValue("SPERRIN COMPONENT NUMBERS - INVENTOR USE.xlsm", "DRIVE IN 0R THROUGH RAIL", "E21") = component_type
GoExcel.CurrentCellValue("E21") = Right_Rail
GoExcel.CellValue("SPERRIN COMPONENT NUMBERS - INVENTOR USE.xlsm", "DRIVE IN 0R THROUGH RAIL", "F21") = component_type
GoExcel.CurrentCellValue("F21") = "NONE REQUIRED"
GoExcel.CellValue("SPERRIN COMPONENT NUMBERS - INVENTOR USE.xlsm", "DRIVE IN 0R THROUGH RAIL", "G21") = component_type
GoExcel.CurrentCellValue("G21") = "REQUIRED"
Componen=GoExcel.CellValue("SPERRIN COMPONENT NUMBERS - INVENTOR USE.xlsm", "DRIVE IN 0R THROUGH RAIL", "C23")
iProperties.Value("Right Rail", "Part Number")=Componen
PN =iProperties.Value("Project", "Part Number")
MessageBox.Show("RAIL RIGHT:  " & PN, "Part Number Confirm",MessageBoxButtons.OK)
iLogicVb.UpdateWhenDone = True
If Right_On = True And Left_On = False And Center_On = False And Connecting_Plate_On = False
GoExcel.CurrentCellValue("G21") = "NONE REQUIRED"
iProperties.Value("Project", "Part Number")=Componen
If Left_On = True And Right_On = True And Center_On = False And Connecting_Plate_On = False
GoExcel.CurrentCellValue("F21") = "LEFT HAND END"
GoExcel.CurrentCellValue("E21") = Left_Rail
MessageBox.Show("RAIL LEFT:  " & PN, "Part Number Confirm",MessageBoxButtons.OK)
If Left_On = True And Right_On = True And Center_On = False And Connecting_Plate_On = True
If Right_On = True And Left_On = True And Center_On = True And Connecting_Plate_On = True
GoExcel.CurrentCellValue("E21") = Center_Rail
GoExcel.CurrentCellValue("F21") = "BOTH ENDS"
MessageBox.Show("RAIL CENTER:  " & PN, "Part Number Confirm",MessageBoxButtons.OK)
If Right_On = True And Left_On = True And Center_On = True And Connecting_Plate_On = False
Message 8 of 11
sperrin658
The 'Right_On', 'Left_On' and 'Center_On' refer to which parts are active in the assembly. Ihave more ilogic done to change these options in the assembly.
Thanks for the help!
Message 9 of 11
Hi sperrin658,
The very first thing I notice is in the first If/Then block, there is a line that reads:
iProperties.Value("Right Rail", "Part Number") = Componen
I think this is meant to read:
I hope this helps.
Curtis
Message 10 of 11
Hi sperrin658,
The next thing I see, is that you are setting the Part Number twice per If/Then block. So the first time you set it, gets overwritten be the second time (see green arrows).
Edit: I'm jumping back and forth between looking at this and working on other things, but I just noticed that your IF statement don't have any Thens or Elses, so I think your code has some issues, but I've not realy had time to look at it closely.  Hopefully this will get you started though.
I hope this helps.
Curtis
Message 11 of 11
sperrin658
I sorted that bit after i had copied it onto the post. I need two separate part numbers cause theres two parts within the assembly with two different numbers, thats why theres no "else ifs".
Thanks for the help.
