I have a rope part that I have to show in my drawing in its strait form and its looped and locked form. So I made two models, one strait and one looped. However I was wondering if I can do this as an iPart by taking the strait part and bending it to the loop version. However, when I tried it, I could not get the last bend to work because it would not bend onto its self. Is there another way to do this so that I do not have to create two parts?
Solved by mcgyvr. Go to Solution.
Hi cadcamm,
the bend command would be likely tricky with a cylindrical shape...
You can simply control the sketch angles as parameters
Here a visual example with iLogic
, in your case iParts should works fine.
Hope that it can helps you.
Admaiora
"If" the rope was modeled as a part (well an ipart to show straight/looped) and then the ferrules (or whatever those are) were added onto each end in the assembly environment then there wouldn't be any self-intersection in the ipart and it would work just fine.
In the "real world" thats an assembly anyways. right?
Even if you buy it in one part its still an assembly and it should be modeled in Inventor as such.
I'm just wondering how the zero deg bends were made in the video. I tried to make my bend zero degree and I recieved an error.
No zero bend, but degrees in the angles
See file attached.
I hope that it can helps you.
Admaiora
It seems when your bending your part, it is growing in size because your adding the radius. It doesn't take in account the length of the bend radius. I tried this before. That is why I was using the Bend command because it literally bends the part taking in account the length of the bend radius.
It was an idea, you can easily complete using arc length parameter instead an angle parameter or a little iLogic.
Admaiora
