Inventor General
Member
jgaston
Message 1 of 3 (200 Views)
Parametrized elbow
200 Views, 2 Replies
08-10-2012 01:25 AM
I have an elbow parameterized with sheet metal parts and structure.
The assembly is based on a parameterized skeleton, in which one of the parameters is the angle.
To create the structure of one end of the elbow, the edges of the skeleton use as reference. (elbow_45.jpg)
The problem arises when the value of the angle change, as some of the frame component are misaligned (elbow_90.jpg).
I know there is a version solicion in 2013, but I'm working on the 2012. Anyone know of any alternative solution?
Thanks!
Message 2 of 3 (162 Views)
Re: Parametrized elbow
08-10-2012 08:10 AM in reply to: jgaston
Can you post your assemly and parts in a zip file?  It's hard to know exactly what is happening here without seeing the model.
I'll venture a guess that some assembly constraints are the cause of the trouble.  Is the problem only with the two support angles that are on the curved faces?  How did you constrain them to your skeleton?  Edge to edge?
Employee
Message 3 of 3 (131 Views)
08-10-2012 02:46 PM in reply to: jgaston
Hi! If I understand this issue correctly, it is about the frame members misalign when reference source geometry tranforms in the model space. This is a known limitation in R2012 unfortunately. The issue here is that the frame member is not aware of the alignment. When the reference part changes shape resulting in relocating the frames, the frame alignment may not adjust accordingly.
In R2013, Frame Generator provides Align option. If a member is edited, you can pick an alignment reference (plane or edge). Then as long as the alignment reference geometry exists, the frame should align accordingly.
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
