There is the nominal value and the model value, which are always the same, even when i insert a formula.
I know, from the help, what they mean.
My question is why do i need both? are there situations where the formula result doesn't match the model value=the actual size of the param'?
Try experimenting with Tolerances (Tools>Document Settings>Tolerances tab).
And setting a dimension at upper or lower tolerance.
i set tolerance to 0.3 and precision to 0.1
I set, for two parameters, lower and upper tolerance, but i still see the nominal and the model values are equal: 20.0000
I don't understand the logic behind tolerances and precision.
I have set tolerances, as in the picture, and the diameter parameter of size 20 became 20.3. why?
How do tolerances work, how are they applied
I understood that since there is a global precision of 3 places, then the tolerance for 3 places is taken.
But where do i set this document setting of precision?
I did it with a right clik on a dimension, but, on the tools menu, document settings it isn't
