Inventor General
New Member
Message 1 of 2 (289 Views)
Parameters in weld symbols
289 Views, 1 Replies
03-12-2012 10:22 AM
I am creating a weldment that is controlled using parameters that are linked to an Excel spreadsheet (using Inventor 2012). One of my parameters is the size of the weld bead. I am able to add the parameter to change the visible size of th fillet and groove welds but am unable to have the weld symbols update to show the parameter value. Does anyone know how to add the parameter to the weld symbols? Or is this not possible?
Valued Mentor
jeanchile
Message 2 of 2 (282 Views)
Re: Parameters in weld symbols
03-12-2012 11:26 AM in reply to: tottenhof
You might try this:
1.) When you create the weld in IV there is an option to show the weld symbols somewhere (on my phone right now so this is the best info I have). Make sure the weld symbols are there.
2.) Retrieve the weld symbols in your drawings directly from the model.
I may be wrong but this should have your excel sheet drive the weld feature, the weld feature drive the symbol, the model symbol drive the drawing symbol and then everything should work (in theory, I've never done this exact thing).
Good luck.
Inventor Professional 2013 (SP-2.3), Product Design Suite Ultimate
Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (331.81), Space Pilot Pro (3.16.1)
Laptop: Intel Core i7 3.9GHz, 16.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTX 780 (331.81), SpaceNavigator (3.17.7)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
