Inventor General
*Expert Elite*
Cadmanto
Message 1 of 5 (109 Views)
Accepted Solution
Parameters Where are they?
109 Views, 4 Replies
05-24-2012 11:41 AM
If I have a part with a variety of features and associated dimensions, I should be able to go to the manage tab and select "Parameters" and see those dimensions in the dialog window right?
If there is no (+) next to the "Model Parameters" how do I get the list to populate with the dimension variables?
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Valued Mentor
japike
Message 2 of 5 (102 Views)
Re: Parameters Where are they?
05-24-2012 11:47 AM in reply to: Cadmanto
Are you using any parameter filters? Look at the lower left of the parameters window.
Peace,
Jeff
Inventor 2013
*Expert Elite*
Cadmanto
Message 3 of 5 (96 Views)
05-24-2012 11:59 AM in reply to: japike
Not intentially.
This is how it comes up when I bring up the parameters.
What should it be set to as a default?
Best Regards,
Scott McFadden
Valued Mentor
japike
Message 4 of 5 (93 Views)
05-24-2012 12:04 PM in reply to: Cadmanto
If you click on the upper left icon (the one with the green check mark), you will get a drop down menu - all should be checked.
Peace,
Jeff
Inventor 2013
*Expert Elite*
Cadmanto
Message 5 of 5 (83 Views)
05-24-2012 12:48 PM in reply to: japike
Thank you.  Once I selected the "All" they showed up.
Best Regards,
Scott McFadden
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
