If I have a part with a variety of features and associated dimensions, I should be able to go to the manage tab and select "Parameters" and see those dimensions in the dialog window right?
If there is no (+) next to the "Model Parameters" how do I get the list to populate with the dimension variables?
Solved by japike. Go to Solution.
Not intentially.
This is how it comes up when I bring up the parameters.
What should it be set to as a default?
If you click on the upper left icon (the one with the green check mark), you will get a drop down menu - all should be checked.
