Inventor Forum
Parameters Sequence in iLogic Form
4 REPLIES 4
zdhrichard
863 Views, 4 Replies
I am trying to use iLogic Form in Inventor.
I used "Row" in Toolbox. And I pulled my parameters in sequance.
But when I run this Form, the parameters are not in sequence which I defined.
Does any body know how to fix it?
Is it some mistake I made or is it Inventor issue?
Rich
Autodesk Inventor Professional 2018 (64 Bit Edition)
Build: 284, Release 2018.3
Windows 7 Professional Service Pack 1
Intel(R) Xeon(R) CPU E5645
12.0 GB Memory
4 REPLIES 4
zdhrichard
in reply to: zdhrichard
I am trying to add some pictures for you to understand my issue.
Rich
12.0 GB Memory
mrattray
Using rows in the form editor is rather unintuitive. You'll probably need to use a convoluted combination of rows and groups. Can you give me a better idea of what you want it to look like?
Mike (not Matt) Rattray
Hi zdhrichard,
I think if you employ some Groups in your form, you'll get what you're after. See these links:
http://forums.autodesk.com/t5/Inventor-General/Rows-in-iLogic-Form-Builder-Not-Working-Properly/td-p...
http://forums.autodesk.com/t5/Inventor-General/iLogic-form-format/m-p/4366143#M479584
  Edit: Fixed the link above (thanks Mike!)
Also see the last video on this page:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-656A8515-BAD9-419D-95D0-E1775920C273
I hope this helps.
Curtis
The second link you posted is broken.
