Inventor Forum
Parameter precision in Form
5 REPLIES 5
fakeru
637 Views, 5 Replies
I have the following problem:
I have created a form in which I need to see the volume value. For that I created a User Parameter that is set to be equal with part's volume:
Volume=iProperties.Volume
What I don't like is that the precision for the parameter is too long and I can't change it...
 I changed the precision in Document Settings and also for the parameter itself in the Parameters window, but these changed don't affect what is the form.
Any solution? A precision of 1.1 would be good for me.
Alexandru
Autodesk Inventor 2015 Certified Professional
5 REPLIES 5
jletcher
in reply to: fakeru
in ILOGIC use the round decimal precision..
volume=Round (iProperties.Volume,3)
the 3 is number of places..
fakeru
in reply to: jletcher
Unfortunately it works only if the Units are set to meter in Document Settings. I really need to be mm there.  And if so, it still displays too many figures. Please check this in the attached part1 from my first post.
Regards
Alexandru
jletcher
in reply to: fakeru
Go to your form remove the Parameters from the form replace it with iproperties Volume
rhasell
As James mentioned, here is screen capture to help:
The top one is yours, the bottom one is the iProperties.
Reg
2024.2
Please Accept as a solution / Kudos
fakeru
Yes, thank you!
