Yes, the parameter should update when the model is updated.
I tested this functionality and it seems to be working correctly. Can you
please post a specific workflow and possibly a data set? Also, please check
your Document Settings>Drawing [Tab] and be sure you do not have "Defer
Updates" enabled.
Joe Burkel
Autodesk Inventor QA
wrote in message news:5392400@discussion.autodesk.com...
I remember this working for previous Inventor versions (I think).
But when you create a note in an IDW and insert a value from the parameters,
the parameter should update in the text when the part is updated.
I think this problem is associated with the whole issue with drawings not
updating properly in IV11 when a part is updated.
Any one else have these problems with text?
