I have a parameter FLANGE_WIDTH controlling the width flange...
I would like to place a hole approximately half way across the flange, rounded up to the nearest 5 mm.
So if I have a 75 mm flange, I would the hole to be 40 mm from the edge instead of 37.5.
In Excel this would be:
=MROUND((FLANGE_WIDTH/2),5)
Is there a function to accomplish this in Inventor?
I know I can link to Excel, but I would prefer not to have any external references in this instance.
Thanks in advance
Grant
Solved by stephengibson76. Go to Solution.
Search Help for "formulas and equations." This should return the Functions topic. It lists the parameter functions in Inventor.
