Inventor Forum
Parameter Rounding to Multiples - similar to MROUND in Excel
3 REPLIES 3
ggoodey
1702 Views, 3 Replies
I have a parameter FLANGE_WIDTH controlling the width flange...
I would like to place a hole approximately half way across the flange, rounded up to the nearest 5 mm.
So if I have a 75 mm flange, I would the hole to be 40 mm from the edge instead of 37.5.
In Excel this would be:
=MROUND((FLANGE_WIDTH/2),5)
Is there a function to accomplish this in Inventor?
I know I can link to Excel, but I would prefer not to have any external references in this instance.
Thanks in advance
Grant
3 REPLIES 3
stephengibson76
in reply to: ggoodey
round(( Flange_Width / 2 mm ) / 5 ul) * 5 mm
type this in for your hole distance, you could use the floor or ceiling function if you wanted the hole to move a certain way
Stephen Gibson
View stephen gibson's profile on LinkedIn
in reply to: stephengibson76
Search Help for "formulas and equations." This should return the Functions topic. It lists the parameter functions in Inventor.
ggoodey
Brilliant!
Thank you both.
Grant
