The new IPJ that is created with a Pack and Go, under the Folder Options, Templates and Content Center Files change with the new project. However, Design Data remains set to the Application Options even though Design Data is copied with all other files..
Tested in 2012, 2013, 2014 - all with same results.
Is this by design or fluke?
Andy
Andy,
From the Product Support side we see this to on all releases. Once the IPJ is copied locally it will follow application options settings because those folders are there and created. My thoughts are it cannot honors the customer paths in the Pack and Go as they might not be created. So I believe this is by design.
If you would like to enter a wish list item asking for this to be considered as an enhancement please use the following link.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Don
