Inventor General
Distinguished Contributor
eveylynne
Message 1 of 5 (351 Views)
Accepted Solution
Pack & Go insight
351 Views, 4 Replies
10-30-2012 06:58 AM
I have about two dozen assemblies. Each has an assembly drawing, and a derived part of that assembly, and often some parts w/in the assembly are derived. (Clear as mud?)
I want to p&g the assemblies to another library within the same project on the same server.  These will become next year's gen of our product.  I don't want any link to last year's data.
If I have the "Keep Fold Hierarchy" selected, an ipj file is created that I can't seem to do anything with.  If I have "Copy to Single Path," I have access to files, and a new project file that I don't need (.ipj).
The attached jpg shows my p&g settings.
If I pack & go the assembly, the assembly drawing and the derived part created from the assembly are not included.
If I p&g the derived part created from the assembly, the assembly drawing is not included, and this part looks to the original assembly, not the new one I just saved.  Any derived parts within the new assembly also look to the original source, not the pack and go. I don't know how to make any derived file look to a new source.
if I p&g the assembly drawing, the derived part is not included.  The drawing looks to the original assembly.  I don't know how to make it look to the new one.
Essentially, I can't p&g a file and have all the info transferred, and everything looks to the original files, not the p&g'd stuff.
My request is advice.  I know in SW, I could rename the files as they were p&g'd, and select drawings/derived parts/etc, and they'd all look to the right everything.
Right now, I'm redrawing the idw's and remodeling the derived part of the assembly, after I replace components within the new assembly.
Distinguished Mentor
ampster
Message 2 of 5 (345 Views)
Re: Pack & Go insight
10-30-2012 07:02 AM in reply to: eveylynne
pack n go the drawing file and manually copy the derived
or look into using Design Assistant to create your copy.
With either option you could (should?) use Project Files to keep everything separate.
eveylynne
Message 3 of 5 (331 Views)
10-30-2012 07:23 AM in reply to: ampster
If I manually copy the derive, how do I get it to look to the new copy?  Or do you mean remodel the derived part?
/reasearching DA
Alas, the IV department is a year old tomorrow.  We only recently created our own ipj rather than using the default, and that was only done because the default was causing errors when we updated to a new version of IV.  I imagine a new ipj for next year would be helpful, but I don't see it being created just yet.
Thank you!!
*Expert Elite*
Curtis_Waguespack
Message 4 of 5 (323 Views)
10-30-2012 07:45 AM in reply to: eveylynne
Hi eveylynne,
Depending on the version of Inventor are you using, you might be able to use the iLogic Design Copy tool as well. It was included in the 2012 and 2013 versions. It will copy and update the internal links of an assembly. Note that you don't need to have used iLogic to use the iLogic Design Copy tool.
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/3364-Show_Me_3364/3365-Show_Me_3365/3747-iLogic3...
You might determine that it is not the correct tool for your task, but it's worth looking into.
Paul covers several other copy tools here:
http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
ampster
Message 5 of 5 (307 Views)
10-30-2012 07:58 AM in reply to: eveylynne
not too sure there is a way to make the derived part look at the newly created copy of the assy without using Project Files, not without doing some extra work at least.
I'd follow Curtis's advice on this one if you have one of the newer versions of Inventor.
If not, the DA might be the ticket.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
