Inventor General
karthur1
Message 11 of 71 (523 Views)
Re: PETITION: Add CANCEL or ESC Command
04-09-2012 01:28 PM in reply to: dick_upton
If it is added, I would like the option to turn it on/off in the application options.  I dont really think that it is needed and I only think it would slow Inventor down.
On rare occasions Inventor will hang, then I just use ctrl-alt-del and end the task. Not really sure if the esc key would help in that situation.
CelticDesignServices
Message 12 of 71 (517 Views)
04-09-2012 01:39 PM in reply to: dick_upton
Agree!!!!
Along with the request of In-Stream modifiers for dimensions, which I've been begging for since Rev 5.3.
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
Distinguished Contributor
dick_upton
Message 13 of 71 (479 Views)
04-16-2012 04:29 AM in reply to: CelticDesignServices
Here is a list of very familiar names that all agreed in 2006 that a Cancel Command function is needed:
Albert Allen
Richard Hinterholler
Patrick Berry
http://tinyurl.com/6pgmhw4
That was 6 years ago that this was requested.
dick_upton
Message 14 of 71 (448 Views)
04-16-2012 05:13 PM in reply to: ampster
mcgyver, you agreed 6 years ago that a Cancel Command feature would be useful:
http://forums.autodesk.com/t5/Autodesk-Inventor/Is-there-any-way-to-have-the-cancel-button-actually-...
ampster, Even if you don't agree, there are plenty that do, like:
Patrick Berry,
Lon Neufeld,
Curtis_Waguespack,
WalkerRA,
kpanek,
all 6 years ago, in 2006: http://preview.tinyurl.com/6owxtfg
*Pro
ampster
Message 15 of 71 (426 Views)
04-17-2012 04:53 AM in reply to: dick_upton
Well,
Good Luck!
edit, come to think of it, does any solid modeling application provide an cancel/escape option?
trumpy81
Message 16 of 71 (411 Views)
04-17-2012 02:16 PM in reply to: ampster
Not that I'm aware of, probably because in order to have such a feature would require access to hardware level interupts. Most OS's block that level of access making it very difficult for any programmer to actually use a hardware level interupt. If they didn't, then there would be a lot more, very, very, deadly virus's out there.
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
kellings
Message 17 of 71 (409 Views)
04-17-2012 02:26 PM in reply to: karthur1
What are in stream modifiers again? I know this has been a big deal for you for many years, but I'm not exactly sure what you are referring to?
dick_upton
Message 18 of 71 (404 Views)
04-17-2012 03:02 PM in reply to: kellings
Looks like the Inventor users are not alone.
Solidworks users rank the Cancel Command in amongst their top ten wishes. Maybe when Autodesk's primary competitor leads the way, that is when they will follow?
http://blog.design-point.com/blog/2012/january/rock-the-vote!-solidworks-top-ten-list-voting-open.as...
dick_upton
Message 19 of 71 (366 Views)
04-18-2012 07:11 AM in reply to: dick_upton
Back in 2006, the Cancel Command was added to the AUGI wishlist, to no avail.
The following notable contributors to the Inventor community all agreed 6 years ago that this feature was needed:
Sean Dotson
Troy Grose
hallstevenson
rimo625
lneufeld
R. Corriveau
http://tinyurl.com/6qgrnvp
mrattray
Message 20 of 71 (361 Views)
04-18-2012 07:19 AM in reply to: dick_upton
I would love it for iLogic rules. I have a lot of assemblies heavy with code and I couldn't tell you how many times I click run rule or regenrate rule instead of edit rule. Then I have to wait 5 minutes for the code to execute.  Or worse, I do it on a rule that eventually closes the file. Then I get to wait 5 minutes for it to execute then another minute to reopen the thing. Very frustrating.
Mike (not Matt) Rattray
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
