Inventor Forum
PETITION: Add CANCEL or ESC Command
70 REPLIES 70
Message 1 of 71
1852 Views, 70 Replies
It's 2012. It's HIGH TIME, Autodesk!! Stop giving us the runaround, feature request form links, the stonewalling. Stop giving us new buttons for the same old features. Listen to your users and stop putting up barricades.
Give us a CANCEL COMMAND or ESCAPE key functionality. A vast host of experienced Inventor users and gurus have begged, pleaded, cajoled for lo these many years. Enough is enough.
If you are a user and agree, please reply that you agree.
Autodesk, in case you haven't been reading these forums, here's a short list of threads throughout the years. The requesters reads like a who's who of Inventor users, mentors, and distinguished contributors. FOR 10 YEARS now:
Starting with:
Leo Laimer, Ed Rassmusen, Peer Hoffmann, 2002: http://tinyurl.com/7bm5ysg
70 REPLIES 70
Message 2 of 71
Sean Dotson and Peer Hoffmann agreed in 2004 that a Cancel Command is needed.
It was requested 9 releases ago: http://tinyurl.com/6s8zgvf
I see also that Donovan Cox also agrees on the tail of the previous thread: http://forums.autodesk.com/t5/Autodesk-Inventor/I-want-a-Cancel-Button/td-p/554799
Message 3 of 71
Ray_Feiler
I agree.
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 4 of 71
blair
I agree with the addition of a Cancel or Esc command as well. I also know that we have for years and with every release of IV complained about speed first.
I can see this adding time, all be it a small amount to the process of each command, as it would require pausing each command process to scan the keyboard during each command, to check that a keyboard command has been issued to interrupt/cancel the operation.
"still miss the Classic UI"
Delta Tau Chi ΔΤΧ
Message 5 of 71
in reply to: blair
Application Options > General > Cancel Command polling > ON/OFF
Message 6 of 71
mcgyvr
I have no need for a cancel/esc command..
On the rare..rare occassion I might need it I would just use task manager and kill Inventor..
<sarcasm>What I would like is that Autodesk just continue moving/redoing the buttons/UI each and every year to keep me from getting bored... </sarcasm>
Message 7 of 71
IgorMir
in reply to: mcgyvr
Funny enough - that's the only wish which is granted unconditionally! Without any sarcasm! LOL!
Web: www.meqc.com.au
Message 8 of 71
in reply to: mcgyvr
Ditto .... lol Man LOL
Message 9 of 71
Teun Ham, Brian Cranston, Johnson Shiue of Autodesk, JDMather, and WDannels all agreed 6 years ago, in 2006
That a Cancel Command is needed: http://tinyurl.com/7xqerjt
Message 10 of 71
ampster401
in reply to: mcgyvr
Ditto.
Now lets post some more about this subject...
That will really have an impact.
Message 11 of 71
karthur1
If it is added, I would like the option to turn it on/off in the application options.  I dont really think that it is needed and I only think it would slow Inventor down.
On rare occasions Inventor will hang, then I just use ctrl-alt-del and end the task. Not really sure if the esc key would help in that situation.
Message 12 of 71
Agree!!!!
Along with the request of In-Stream modifiers for dimensions, which I've been begging for since Rev 5.3.
Message 13 of 71
Here is a list of very familiar names that all agreed in 2006 that a Cancel Command function is needed:
Albert Allen
Richard Hinterholler
Patrick Berry
http://tinyurl.com/6pgmhw4
That was 6 years ago that this was requested.
Message 14 of 71
in reply to: ampster401
mcgyver, you agreed 6 years ago that a Cancel Command feature would be useful:
http://forums.autodesk.com/t5/Autodesk-Inventor/Is-there-any-way-to-have-the-cancel-button-actually-...
ampster, Even if you don't agree, there are plenty that do, like:
Patrick Berry,
Lon Neufeld,
Curtis_Waguespack,
WalkerRA,
kpanek,
all 6 years ago, in 2006: http://preview.tinyurl.com/6owxtfg
Message 15 of 71
ampster401
Well,
Good Luck!
edit, come to think of it, does any solid modeling application provide an cancel/escape option?
Message 16 of 71
Not that I'm aware of, probably because in order to have such a feature would require access to hardware level interupts. Most OS's block that level of access making it very difficult for any programmer to actually use a hardware level interupt. If they didn't, then there would be a lot more, very, very, deadly virus's out there.
Message 17 of 71
kellings
in reply to: karthur1
What are in stream modifiers again? I know this has been a big deal for you for many years, but I'm not exactly sure what you are referring to?
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 18 of 71
in reply to: kellings
Looks like the Inventor users are not alone.
Solidworks users rank the Cancel Command in amongst their top ten wishes. Maybe when Autodesk's primary competitor leads the way, that is when they will follow?
http://blog.design-point.com/blog/2012/january/rock-the-vote!-solidworks-top-ten-list-voting-open.as...
Message 19 of 71
Back in 2006, the Cancel Command was added to the AUGI wishlist, to no avail.
The following notable contributors to the Inventor community all agreed 6 years ago that this feature was needed:
Sean Dotson
Troy Grose
hallstevenson
rimo625
lneufeld
R. Corriveau
http://tinyurl.com/6qgrnvp
Message 20 of 71
mrattray
I would love it for iLogic rules. I have a lot of assemblies heavy with code and I couldn't tell you how many times I click run rule or regenrate rule instead of edit rule. Then I have to wait 5 minutes for the code to execute.  Or worse, I do it on a rule that eventually closes the file. Then I get to wait 5 minutes for it to execute then another minute to reopen the thing. Very frustrating.
Mike (not Matt) Rattray
