Inventor Forum
PERFORATED PANELS
3 REPLIES 3
259 Views, 3 Replies
PERFORATED PANELS
I want to model a perforated sheet metal panel that has some flanges. My first guess as to how to best do this was to model the part with flanges and all, and then go to the flat pattern and create a rectangulre pattern of a cutout feature of some center point circles. However, you can't edit a flat pattern (and that really stinks). What's the best way to do what I want?
3 REPLIES 3
mariox
Hi Mark, you should make a cutoff in the bended part, create a sketch, in the sketch you can project the flat pattern geometry (see under the project tool), then you can create your cutoff selecting the radio button "cut across the bend".
Ciao, Giovanni
Depending on how much perforation you are doing you may want to consider just using
textures instead. Large perf patterns kill performance.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"mark0ms" wrote in message news:f12a2b5.-1@WebX.maYIadrTaRb...
what I want?
Yeah, I'm kind of worried about the performance too. Especially since it's going to be used in an assembly of a piece of test equipment made from a 19-inch standard rack enclosure. The panels come both perforated and unperforated so the plan was to create a factory and substitute the unperforated part in the assembly, and manually edit the parts list. That'll be close enough. Thanks.
