Inventor General
Valued Mentor
stevec781
Message 1 of 6 (182 Views)
Over riding dimension values
182 Views, 5 Replies
06-29-2011 08:53 AM
I know its not a good thing to do but sometimes I need to over ride a dimension value or a BOM cut length.  So that I dont forget about them I am looking for a way to set Inv up so that values that are over ridden are displyed in a different colour or on a different layer.  Is this possible?
*Expert Elite*
jtylerbc
Message 2 of 6 (172 Views)
Re: Over riding dimension values
06-29-2011 09:49 AM in reply to: stevec781
I don't know of one that is completely automatic.  But you could create your layer, then use the selection filter to pick "All Overriden Dimensions", then change the layer on all of them at once.
John Tyler
Inventor 2013
Windows 7 64 Bit
Distinguished Contributor
kstate92
Message 3 of 6 (155 Views)
06-29-2011 10:56 AM in reply to: stevec781
I wonder if an applied override is visible through the VBA or iLogic API...  Probably not.  In the Dark Ages, drawing two lines under a dimension basically meant an 'override' so as not to have to re-draw (by hand) an existing print.  Shame there's not a way add an underline to the dimension - at least not in 2010 - that I can see.
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
*Expert Elite*
Curtis_Waguespack
Message 4 of 6 (142 Views)
06-29-2011 01:33 PM in reply to: stevec781
Hi stevec781
Here is a link with an example of using iLogic to do this:
http://inventortrenches.blogspot.com/2011/06/using-ilogic-to-find-dimension.html
It's not perfect, but it'll get the the job done.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
Curtis_Waguespack
Message 5 of 6 (99 Views)
07-05-2011 08:38 AM in reply to: Curtis_Waguespack
Hi stevec781,
I just updated this rule at this link to include a few improvements:
I hope this helps.
Curtis
Valued Mentor
stevec781
Message 6 of 6 (72 Views)
07-05-2011 07:34 PM in reply to: Curtis_Waguespack
Thanks Curtis.  I had thought of VBA but hadnt thought of iLogic so will give it a try. BTW love your Mastering Inv book.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
