Solved by JDMather. Go to Solution.
George there is not attachment
Admaiora
@georgemuttathil7972 wrote:
.... Dynamic Simulation does not seem to be the proper tool. ....
How did you come to this conclusion?
Can't you add a Trace to a point in the assembly for the Output Grapher, export to a part sketch, or to export to Excel?
... Let me know if you think DS is the right tool for this. Thanks again. George
DS is the only way that I know of to do what you want automatically. Otherwise the only method I know would be laboriously manual, move/inquire/move/inquire......
You can ignore parameters that you are not interested in.
What browser are you using to attempt "attaching" files here.
Instead of using the image or video tool - try using the Attachments - Choose file.
If that doesn't work, right click on the file and select Send to Compressed (zipped) Folder and then attempt Attaching the resulting *.zip file.
Try different browsers, IE, Chrome....
Well, that is pretty impressive that you figured it out without a hundred questions.
It takes a while to learn DS and there are lots of undocumented tricks.
I've been at it for several years and am just starting to figure out like maybe I know something about DS.
