Inventor General
Member
Message 1 of 9 (420 Views)
Origin and line midpoints not turning green
420 Views, 8 Replies
05-21-2012 08:15 PM
for some silly reason all of a sudden when i create a circle on the origin  it is not turning green and constraining the circle to it. Also when i am creating a line from the midpoint of another line the midpoint is not turning green and the line is not constrained to that point. Anybody have any ideas? I have checked the autoproject origin box in the appl settings and it is active.
blair
Message 2 of 9 (415 Views)
Re: Origin and line midpoints not turning green
05-21-2012 09:12 PM in reply to: mattfurches
Check that your Constraint Persistants and Constraint Inferance have not been turned off. Enter Sketch mode, from the Constraint drop-down menu make sure that they are selected.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Member
Message 3 of 9 (405 Views)
05-22-2012 04:44 AM in reply to: blair
i have checked the persistence and it is on. Anybody else?
Employee
Message 4 of 9 (401 Views)
05-22-2012 05:03 AM in reply to: mattfurches
In the same "Constrain" pull-down, click Constraint Options and verify that coincident and midpoint are checked.
Patrick Miller
Senior Content Developer
Member
Message 5 of 9 (398 Views)
05-22-2012 05:11 AM in reply to: patrick.miller
In my constrain drop down box i dont have an options button.
Message 6 of 9 (395 Views)
05-22-2012 05:13 AM in reply to: mattfurches
While in sketch environment right click in the graphics window and select Constraint Options.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
trumpy81
Message 7 of 9 (391 Views)
05-22-2012 05:21 AM in reply to: mattfurches
Does the attached image help?
I have been having similar problems, but it is quite random and only seems to happen at certain zoom levels. Sometimes I'm able to attach to the midpoints etc... as per normal, and sometimes the mouse becomes a little erratic and I cannot always select the point or line directly.
Although the points usually do show and change color as expected.
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
Member
Message 8 of 9 (377 Views)
05-22-2012 10:07 AM in reply to: trumpy81
it was the contraint options. for some unknown reason all the options had become unchecked. thanks for the help.
Active Member
Message 9 of 9 (266 Views)
11-16-2012 02:00 AM in reply to: mattfurches
right click --->constraint options ---->select all ----->apply.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
