Thanks Kevin,
That worked. I just had to zoom in on the intersection so I could see
the dot.
On Mon, 11 Aug 2003 06:13:10 -0700, "Kevin Wehner"
wrote:
>I think someone has a avi file to illustrate this. You may want to look
>through ICF.
>Basically, if you run your cursor along the edge and drag toward the sharp
>corner, you should see a hidden line appear between the part and your
>cursor. Do the same for the other edge and when you are over the
>intersection, you'll get a green dot. Click there and it should put the
>dimension where you want it.
