Hey,
I was wondering if their is a option that would display the force value on the part in FEA.
I know their is a option for displaying the maximum and minimum for results (stress, displacement, safety factor etc.)
I am using autodesk 2014 student version.
Solved by admaiora. Go to Solution.
What do you mean by "force"?
You have many results after analysis: Von Mises, displacement, FOS, etc
Of those eresults you can have and visualize max and min and you can inspect local values with the Probe command.
Admaiora
Are you looking for Reaction Forces (right click on constraint)?
Can you attach your file here?
The force on the part is displaced by yellow arrows. I have about 17.5N on each force arrow.
Is their a quick option to display the force value of 17.5N? Because I typically use a snip tool to put it into a PowerPoint.
I was told the 2012 inventor has that option.
See image.
Hi Vikram,
no, there is not option for that.
There is for Frame Analysis but not for stress analysis.
All you can do is rename in the browser the forces and include the browser in the screenshot
Admaiora
If we could display the magnitude of applied force(s) somewhere on the screen would help get a fast screenshot including results and scenarios without needing to produce a report.
