Inventor General
Member
riido
Message 1 of 12 (256 Views)
Optimal positioning
256 Views, 11 Replies
04-05-2013 05:38 AM
Hi!
I want to place circles (all the same size) onto a confined area in a sketch so that they don't touch and that they optimally cover the area.
Can this be done with Inventor? Or AutoCAD? Or anything else for that matter?
Thanks!
Riido
Active Contributor
jameslovell4987
Message 2 of 12 (251 Views)
Re: Optimal positioning
04-05-2013 05:51 AM in reply to: riido
the optimal placement of circles are out from a central circle... its the nature of the beast :smileyhappy:
what are the size contraints and how far apart must they be?
James Lovell
Windows 7 Professional (64-Bit)
Dell T5600 - Xeon E3-2687W 8(16) Core CPU
16GB ECC RAM, 2GB Quadro 4000, 256GB SSD
Autodesk Product Design Suite Ultimate 2015
Member
riido
Message 3 of 12 (240 Views)
04-05-2013 06:02 AM in reply to: jameslovell4987
It is for LED advertisement texts. You have to position the LEDs inside letters as uniformly as possible so that the letter will be evenly bright. I use circles to signify a tested radius of an LEDs effective lighting.
*Expert Elite*
mcgyvr
Message 4 of 12 (213 Views)
04-05-2013 07:47 AM in reply to: riido
Nope.. It has been a requested feature but never implemented.
But just use an array and suppress the ones you don't need.
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Member
riido
Message 5 of 12 (176 Views)
04-08-2013 06:16 AM in reply to: riido
It's too time consuming to do it by hand on some more elaborate fonts.
Does anybody know of a different software capable of doing this and exporting the result to either AutoCAD or Inventor?
Distinguished Mentor
swhite
Message 6 of 12 (172 Views)
04-08-2013 06:28 AM in reply to: riido
Are the circles all the same size, or different for each LED? And i suspect the area is not always square, rectangle or round?
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Member
riido
Message 7 of 12 (168 Views)
04-08-2013 06:33 AM in reply to: swhite
All circles are the same size for one sign.
*Expert Elite*
JDMather
Message 8 of 12 (154 Views)
04-08-2013 07:57 AM in reply to: riido
riido wrote:
Does anybody know of a different software capable of doing this .....?
You might be able to do this in SolidWorks with Fill Pattern (quick and dirty example shown).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
mcgyvr
Message 9 of 12 (132 Views)
04-08-2013 10:11 AM in reply to: JDMather
^^ Wonder how long solidworks has had that functionality.. that is NEAT. (and useful..I can think of a half a dozen times in the last year or so that I could have used that functionality..)
Windows 7 64 bit
swhite
Message 10 of 12 (121 Views)
04-08-2013 10:45 AM in reply to: riido
No circle fill in inventor? perhaps you should look into making a fill type for what you need, but I expect it wouldn't work the same and would cut circles off where they crossed the edges.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
16 GB RAM
Windows 7 - 64 Bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
