Inventor Forum
Optimal positioning
11 REPLIES 11
Message 1 of 12
451 Views, 11 Replies
Optimal positioning
Hi!
I want to place circles (all the same size) onto a confined area in a sketch so that they don't touch and that they optimally cover the area.
Can this be done with Inventor? Or AutoCAD? Or anything else for that matter?
Thanks!
Riido
11 REPLIES 11
Message 2 of 12
JamesLovell
the optimal placement of circles are out from a central circle... its the nature of the beast 🙂
what are the size contraints and how far apart must they be?
James Lovell
Windows 10 Professional (64-Bit)
AMD Ryzen 9 3900X 12 Core CPU
32GB Corsair VENGEANCE DDR4 3200MHz,QUADRO RTX 4000, 1TB CORSAIR MP600 GEN 4 PCIe NVMe
Product Design & Manufacturing Collection
Message 3 of 12
in reply to: JamesLovell
It is for LED advertisement texts. You have to position the LEDs inside letters as uniformly as possible so that the letter will be evenly bright. I use circles to signify a tested radius of an LEDs effective lighting.
Message 4 of 12
mcgyvr
Nope.. It has been a requested feature but never implemented.
But just use an array and suppress the ones you don't need.
Message 5 of 12
It's too time consuming to do it by hand on some more elaborate fonts.
Does anybody know of a different software capable of doing this and exporting the result to either AutoCAD or Inventor?
Message 6 of 12
Are the circles all the same size, or different for each LED? And i suspect the area is not always square, rectangle or round?
Message 7 of 12
All circles are the same size for one sign.
Message 8 of 12
JDMather
@Anonymous wrote:
Does anybody know of a different software capable of doing this .....?
You might be able to do this in SolidWorks with Fill Pattern (quick and dirty example shown).
Message 9 of 12
mcgyvr
in reply to: JDMather
^^ Wonder how long solidworks has had that functionality.. that is NEAT. (and useful..I can think of a half a dozen times in the last year or so that I could have used that functionality..)
Message 10 of 12
No circle fill in inventor? perhaps you should look into making a fill type for what you need, but I expect it wouldn't work the same and would cut circles off where they crossed the edges.
Message 11 of 12
There is a program that can do this, I just discovered.
Here is a short video:
http://screencast.com/t/5N8FYZta38T
Is such a thing really not possible in Inventor OR SW?
PS. I tried Fill Pattern in SW, but the end result was less than satisfactory, though I'm not sure it isn't down to user-error on my behalf.
Message 12 of 12
VdVeek
Have a look at: http://modthemachine.typepad.com/my_weblog/2013/03/control-feature-creation-based-on-user-defined-bo... that looks a bit like you are looking for.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
