For some reason I no longer have the option were I can pick open from content center. I use to have the option but it does not exist anymore. The only option's I have now are Open, Open DWG, Open from Vault & Import DWG. I am missing Open from Content Center, Open Fusion DWG.
Are you still using the same MP file? Or did it go back to the feault one.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
If you mean manage project it is the same one that I always used. I have another coworker who is working in the same project on his machine and he does have the option to select open from content center in his Inventor.
Robert
Yes, master project.
Have you tried rebooting your machine?
I have and it did not add the option to open from Content Center
Robert
Robert,
Are you seeing the CC at all?
I mean can you add parts from the CC in an assembly?
Sounds like you might have a network user profile that's gotten a little messed up. Have your network IT person look at your user profile for your machine.
