What I am not understanding is, if you create a model then create a drawing using that model, and you save both, are you saving the drawing into a different directory or moving the drawing alone into a different directory then the model after you create it? Are your drawings on a network and if so are you having network issues?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Best Regards,
Scott McFadden
(Colossians 3:23-25)
