Inventor Forum
Opel Cell Metal Foam
3 REPLIES 3
1747 Views, 3 Replies
Hi, I need to create a cube, made of a open cell metal foam. It is really hard to made this manually. So is there any function to create such a material (with a random generator or a structur generator)? I attach a picture of the material which I need as a 3D model.
3 REPLIES 3
blair
In a short, no. If you modeled this as shown it would bring Inventor to it's knees with the amount of features. The best would be to create a custom material with the correct density and apply a bit-map image for appearance.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
Ok tank you. I would like to realize that through a hollow cell that I copy several times and arrange together. But how can I build a hollow cell? I would to create a cube and a second cube. I want to rotate the second cube so that its corners stand out on the surfaces of the first cube. Then I want to remove the volume of the second cube from the first, so make a cube with holes. But why can I rotate a second cube and why can I remove the volume?
JDMather
There is no need to create second cube.
Simply Extrude - Cut a square by disance equal to side.
If you really want to use two cubes -
you can use Move Body and Combine - Cut
or
Derived Components.
I recommend that you first go through the built in Help>Learning Tools>Tutorials and Skill Builders
and then
attach your attempt here.
The process you desribe (of cutting one cube from another) would not result in geometry that matches your original image.
Has your design intent changed?
