Inventor Forum
Opaque Balloons in IDW
9 REPLIES 9
Message 1 of 10
ClintWestwood
654 Views, 9 Replies
Is it possible to make balloons opaque in the IDW environment? I have several instances where the best location for a ballon is over hatched regions or part edges, and the extra lines make the balloon numbers hard to read.
Inventor 2014
HP Pavilion dv6t-6b00
Intel Core i7 2670QM
AMD Radeon HD 6490M
16gb RAM
Windows 7 64 bit
3Dconnexion SpaceExplorer
9 REPLIES 9
Message 2 of 10
mcgyvr
in reply to: ClintWestwood
tools..document settings..drawing tab and turn on "cross hatch clipping"
Message 3 of 10
ClintWestwood
in reply to: mcgyvr
Thanks for the tip. However... it didn't seem to do the trick.
My hatches are contained in a 2D sketch which is linked to the view, with the outlines being projected. My balloons are the default style, with overriden numbers.
Anything else I can try?
Inventor 2014
AMD Radeon HD 6490M
16gb RAM
Windows 7 64 bit
Message 4 of 10
-niels-
Well, this involves a lot of manual labor, but you could make a sketched symbol and use that as the user defined shape for a balloon...
You'd have to make a sketched symbol containing a circle with a fill color of the size you need.
Then you need to right-click an existing balloon, select edit balloon and override it's shape.
(pick "user defined symbol" and select the sketched symbol from the dropdown.)
If you need more explanation, let me know and i'll try to add some screenshots.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 5 of 10
ClintWestwood
in reply to: -niels-
I created a sketched symbol with a white fill, and used it to override balloon #9 (from my previous post). Still no luck.
Inventor 2014
AMD Radeon HD 6490M
16gb RAM
Windows 7 64 bit
Message 6 of 10
-niels-
Hmm... guess it has something to do with the 2d sketch then...
Is it just a sketch on the view in which you project geometry and then apply a hatch to?
Niels van der Veer
The Netherlands
Message 7 of 10
ClintWestwood
You are correct. I created a sketch on the view, projected the lines I needed, then manually added lines and arcs to close the profiles. It was a very time-consuming process-not sure if there is a better way? You can see one of my sketch lines (closing a profile) in the bottom left of the image where the two components meet.
Inventor 2014
AMD Radeon HD 6490M
16gb RAM
Windows 7 64 bit
Message 8 of 10
mcgyvr
I guess "cross hatch clipping" doesn't apply to hatched sketches.. only section view hatching,etc...
another half finished autodesk function.
Message 9 of 10
-niels-
in reply to: mcgyvr
I'm going to agree with you mcgyvr, i've tried to see if there was a way to change the layer order but there's no luck there either.
I'd say it's a shortcoming of the "cross hatch clipping" functionality, but not sure what the best way to proceed is...
Either add it to the ideastation or get in contact with autodesk to report it as a bug...
Clint, if you add this to the ideastation then add a link here and we'll vote on it.
Niels van der Veer
The Netherlands
Message 10 of 10
ClintWestwood
http://forums.autodesk.com/t5/Inventor-IdeaStation/Increased-cross-hatch-clipping-functionality/idi-...
Inventor 2014
AMD Radeon HD 6490M
16gb RAM
Windows 7 64 bit
